Home › Forums › Products › Stompboxes › Timefactor not passing sound when on…? › Reply To: Timefactor not passing sound when on…?
August 17, 2010 at 6:06 pm
#120676
First try "Restoring Factory Settings" as described in the User Manual.
If this doesn't work, it sounds like a power supply problem. If you are using the supplied power supply you should contact support@eventide.com. If not, you should contact the power supply manufacturer.
