Home › Forums › Products › Stompboxes › Pitchfactor Expression Pedal Problem › Reply To: Pitchfactor Expression Pedal Problem
#120775
parsky1
    So how do I fix this.  When I use the expression pedal for pitchflex and it "recalibrates" it sounds aweful… to the extent it is embarrasing live…..  Sad  This is with the pedal you guys recommended as well…
    There should really be a manual calibration so I can set the travel
