Home Forums Products Stompboxes Time Factor – expression pedal not holding the setting? Reply To: Time Factor – expression pedal not holding the setting?
#120843
    Does this occur with the pedal disconnected ? If not, it probably is the pedal, although it's unclear why it happens with the two pedals. Bad cable or dirt in the socket, maybe ?
    There is the tiniest possibility that it is a hardware fault, but we have no records of this happening. You will have to send it back to us to check this one way or the other.
