Home › Forums › Products › Stompboxes › version 3 installed on both Pitch and Time › Reply To: version 3 installed on both Pitch and Time
#121087
AAgnello
    Normal
    0
    false
    false
    false
    EN-US
    X-NONE
    X-NONE
    Preset Naming
    TimeFactor now gives you the ability to name your Presets. When you load a
    new Preset in Bank Mode, the entire Preset name will scroll once. Then the
    Bank/Preset number will be displayed, followed by the first 4-6 letters of the
    Preset Name.
    To Edit the Preset Name:
    -After entering Save Mode, press the Right Footswitch and the first
    character of the Preset Name will flash. Turning the Encoder will change this
    character. The available character set is 'A-Z','a-z', '0-9'.
    – The Left and Right Footswitch LEDs will be flashing green, to show that
    TimeFactor is in Save Mode and that these switches can be used to navigate
    between edit fields.
    – Use the Left and Right Footswitches to traverse the display, selecting a
    field to be edited by the Encoder. (The active field for editing is always
    flashing.) Repeated pressing of the Right or Left Footswitch will traverse
    through the name field one character at a time, flashing the selected
    character.
    – The cursor will “wrap around the display,” ie Pressing the Left Footswitch
    will move the edit field to the left by one character at a time until it gets
    to the first character. Pressing the Left Footswitch from here will jump to the
    last character of the Preset Name.
    – A phantom space is always present at the end of the name to allow
    characters to be added past the end. This cannot be deleted but will be removed
    on exit.
    -When you are finished naming, either press and hold the Encoder Button to
    save the Preset, or press the Middle Footswitch to exit without saving.
    Special Footswitch Presses/Shortcuts for Naming Presets:
    1. Press and hold Left Footswitch to DELETE the current flashing character.
    2. Press and hold Right Footswitch to INSERT a character before the current
    flashing character.
