Home Forums Products Stompboxes Question about using Eventide TimeFactor’s both inputs, with another delay in front Reply To: Question about using Eventide TimeFactor’s both inputs, with another delay in front
#121197
Thanks for your reply!
Well, the thickening delay only has one input, so it can't be used after the TimeFactor in a stereo configuration. But, since the TF will be the last in my chain, the thickening delay will be right in front of it and the TF will be off (in relay mode) when I will most need thickening, so I think it would all be ok.
Regarding the delay time, do you think 20 ms is too much for what I'm looking for? (thickening vs. reverby ambience). I know a DDL would go under 20 ms, but I so want to use a good quality, warm but clear analog delay!…
Thanks again!
