Reply To: Changing a switch in TimeFactor
Home Forums Products Stompboxes Changing a switch in TimeFactor Reply To: Changing a switch in TimeFactor
#121330
Dr.Jackle
Thank you for the answer. I bought the unit two years ago and don't have the original receipt anymore, so I assume it is surely out of warranty. The switch works most of the time, but I know from experience (I've had same symptoms with other pedal) it is only a matter of time that the switch has to be replaced. I haven't done anything to the pedal yet, just opened the back plate to inspect what the problem might be, and thought I'd ask for some advice before proceeding.
What kind of switch should I buy, and is there some particular things I ought to be careful with, other than the obvious, like not heating the joint too much when replacing the switch?
Thanks,
Dr.Jackle
