Reply To: using Ground Control Pro w/ the Time Factor?
Home Forums Products Stompboxes using Ground Control Pro w/ the Time Factor? Reply To: using Ground Control Pro w/ the Time Factor?
#121353
badmelonfarmer
Not tried it with the Ground Control, personally…. but I do not see why it would not work for things like bypass etc.
the one word of causion is that the Factor boxes use CC for tap tempo with a value of over 64(?) for the beat pulse. so if your midi controller has a On/Off CC method, like my Rocktron Midimate then only 1 in 2 clicks is seen as a "beat" due to the time factor not listening to the "0" value of one of the clicks.
I have looked at other controllers and a lot of the lower / mid range work this way.
The Ground Control was one I was going to look at next to see if it would work for me.
