Home Forums Products Vsig and Preset Development Inputs & outputs in VSIG Reply To: Inputs & outputs in VSIG
#121529
    The blue inputs are global control inputs for communicating between different presets, usually driven by the C_BRIDGE module.
    The analog and digital inputs are handled by the routing and are not part of the preset, so can't be controlled by Vsig. If you have trouble understanding the routing, try downloading the Routing Utility from the H8000 support page.
    The digital outputs are separate from the analog outputs. Again, this is a routing issue.
