Reply To: Wet dry outputs on the Time Factor (or any other Eventide stompbox)
Home Forums Products Stompboxes Wet dry outputs on the Time Factor (or any other Eventide stompbox) Reply To: Wet dry outputs on the Time Factor (or any other Eventide stompbox)
#121635
No. You have to have one or the other, at any given time. It does sound as if a DPDT switch could be set up to give you what you want (see a local competent tech for more details).
