Home › Forums › Products › Stompboxes › Wet dry outputs on the Time Factor (or any other Eventide stompbox) › Reply To: Wet dry outputs on the Time Factor (or any other Eventide stompbox)
March 5, 2011 at 1:58 am
#121661
Can you be a bit more specific — I'd want to know what to tell a tech …. do you mean add a switch that would, for example, allow the input to be directly wired to one of the outputs so that if the other "half" is set to "wet only" you have a mini parallel loop within the stomp box?
