Home Forums Products Stompboxes timefactor noise Reply To: timefactor noise
#121667
I'd recommend that you send the pedal in for service. Whether or not you use it in the effects loop or in front of the amp isn't the issue, that's a personal choice. It works better for some people in some situations, but isn't a requirement. If I had to guess, the rep who told you to try it in the loop was just trying to determine where the problem was and not suggesting that the pedal *has* to be used in the loop.
