Home › Forums › Products › Stompboxes › Daisy Chaining / Midi Controllers › Reply To: Daisy Chaining / Midi Controllers
April 5, 2011 at 6:22 am
#121880
nickrose:
If you set all the 'Factors to MIDI THRU you can daisy chain them. This will preclude you from using MIDIclock out from the first one – if you want this you will need a "MIDI Merge" box.
Which MIDI merge box do you recommend? Does that mean I could use:
ROLAND FC-200 MIDI FOOT CONTROLLER
OR
FLOORBOARD VETTA BV
OR
Behringer FCB1010
THE GCB is not in my budget. Thanks. 🙂
