Home Forums Products Stompboxes Replacing a Whammy: MIDI question about PF and all of the “Factors” Reply To: Replacing a Whammy: MIDI question about PF and all of the “Factors”
#121886
+1
I think this would be a more elegant solution. For instance, when using the bypass setting in the receive map, unless I'm missing something, there isn't any way to pre-load the next patch without either 2 program changes, a program change and the bypass switch, or an external MIDI controller that can send batches of MIDI commands in one patch. That's not usually a huge problem with the TF, MF, but of some of the algorithms in Space, because of their size and complexity, can take a small amount of time to load. It seems like this can also be an issue in the PF, although it's usually less noticable there. Being able to pre-load the next patch would eliminate this delay, however slight.
I'd still love to see all of them (mostly the MF) transmit their modulators via MIDI CC, too.
