Home › Forums › Products › Stompboxes › Time Factor midi clock out….. › Reply To: Time Factor midi clock out…..
April 8, 2011 at 2:24 pm
#121889
Have you also set the TimeFactor Output to XMT (instead of THRU)? It's at the same System level as the Clk Out setting. The default MIDI Sync setting in the AdrenaLinn III is "in", so that shouldn't be the problem. ("i-o" will also work there, but not "oUt").
