Reply To: Midi control of MF from TF
Home Forums Products Stompboxes Midi control of MF from TF Reply To: Midi control of MF from TF
#121972
krcassid
Fantastic!  Thanks!
I actually do both.  When setting stuff up I typically use a controller that can transmit as many CCs as I want.  But, while in use, my ability to send CCs is limited.  However, I did not realize TF could XMT PCs.  Does it have to be same PC on same channel?  I thought there was no "midi thru" capability on multiple channels.  In other words: can TF transmit a different PC on a different channel than it is receiving?  Otherwise, they'd all have to line up: same PC o same channel on both devices..
