Reply To: MIDI / FS3 / Bank up bug?
Home Forums Products Stompboxes MIDI / FS3 / Bank up bug? Reply To: MIDI / FS3 / Bank up bug?
#121993
Quote:
You may have to check to see what values your controller is sending for the MIDI CC assigned to FS3.
Hardware Test Platform & Setup:
FCB1010 (no UNO chip)
Active switch transmitting none of the 5  program changes, or MIDI note.
Same switch sending any single CC number on MIDI Channel 2.
[not the two CCs available per-switch, and not using the Controller Toggle function – (FCB1010 manual – Section 2.5)]
FCB1010 MIDI OUT to MIDI IN of PitchFactor 3.0.0beta[16]
System settings-> MIDI:
RCV CH: 2
RCV CTL: FS3 > matching CC number on FCB1010
[no other conflicting RCV CTL assignments]
OUTPUT: THRU
CLK IN: OFF
CLK OUT: Tested at both ON & OFF settings
Test Results:
Sent CC value 0-63:
Bank mode: FCB1010 switch does nothing (Tap Tempo unaffected by incoming CC)
Play mode: FCB1010 switch increments Bank number
Sent CC value 64-127:
Bank mode: FCB1010 switch determines Tap Tempo
Play mode: FCB1010 switch determines Tap Tempo
Note: Presets tested alternately at TMP ON and TMP OFF settings with functionally identical results
I have the same results using BK+, BK-, FS1, and FS2 in Bank / Play modes as detailed in the OP.  At one point, I did have difficulty getting FS3 to LEARN via MIDI (RCV CTL + two right button presses), but I can't reproduce those conditions in a "recipe".
