Home Forums Products Stompboxes Updated Timefactor-still not getting patch names plus a bug? Reply To: Updated Timefactor-still not getting patch names plus a bug?
#122011
EdDrake
    Billy Foppiano:
    I have 20 customs patches, so I won't be initialising to Factory Pres. Any ideas, in the Mac world????
    Billy,
    If you only have 20 custom patches you might just want to bite the bullet and write down the settings for those patches then reinitialize the pedal and go from there. Once you get everything reset the Factor Lib seems to work just fine with naming, etc. I think the issue is trying to use saved patches from older software versions, this seems to mess up the patch naming and you get the weird numbers. I only had a few custom patches and they were all just slightly tweaked versions of some of the presets anyway so that's why I went ahead and reset the pedal.
    I think some parameters  were slightly changed in the newest betas which would likely require you to tweak them to get them to sound the same as they did before.
    Just a suggestion, hope it helps.
    Ed
