Home › Forums › Products › Stompboxes › PitchFactor, PitchFlex, and Expression Pedal Programming › Reply To: PitchFactor, PitchFlex, and Expression Pedal Programming
June 24, 2011 at 7:53 pm
#122337
Hi bwheat,
I'm pretty sure it is functioning as it is designed. The expression pedal on that algorithm is only for pitchbending. You could program an aux switch for Mix if you wanted.
-Russ
