Home › Forums › Products › Stompboxes › Expression Pedal and Hot Switch Assignment › Reply To: Expression Pedal and Hot Switch Assignment
June 26, 2011 at 3:54 pm
#122343
Sorry, made a few errors(it was early this morning!) The two pedals I have are the Space and Pitch factor.
Also when only one paameter is assigned to the exp pedal,at least in the PF, I can only see one of the parameters(some times toe and sometimes the heel, depending on the preset). After moving the expression pedal from toe to heel, it appears to stay in expression pedal program mode as the catchup no longer works as the parameter changes immediately with out the turn < or > indicator.
Must say I love both of these pedals!!!
Steve
