Home Forums Products Vsig and Preset Development Supermodules – substitution strings Reply To: Supermodules – substitution strings
#122351
    If you set up substitution strings for a supermodule, the substitutions will occur when the document is saved as a sigfile (or sent to the H8000, which is essentially the same thing). For this reason you should save designs using this feature as a .sif, even though this format is essentially obsolete.
    The purpose of the substitutions is to allow multiple instances of a single supermodule to have different text, without requiring that you go in and manually edit each one.
    As an example, if you use the default substitution target of "^1" set to be replaced by "high", and enter a statement of "^1 band: 10", this will become "high band 10" when the sigfile is saved.
    To see this result, you will have to send it to an H8000, or save the design as a new sigfile and reload it.
