Home Forums Products Stompboxes Space and Timefactor Reply To: Space and Timefactor
#122384
Tim,
I appreciate the response and advice.  This helps out a lot!
I am assuming you have your TF first in your pedal line up and then Space last.  Do you find that some of the presets compete with each other between the two units?  For example, all the TF preset sounds are very rich and full and once you enable Space, wouldn't that drown out what is happening on the TF?  It's almost like you have two different reverbs,delays and modulation happening simultaneously.  Just curious how you approach using both units together.  Do you have to stick to a basic hall and basic delay to get both to compliment each other?
