Home Forums Products Stompboxes Buzzing, hissing Reply To: Buzzing, hissing
#122395
Just so you know, this is incorrect. I was the one with that problem, and it was not the amp. Lots of other people have the problem with different amps. The problem stems from the fact that the Timefactor requires a certain amount of input volume that my guitars couldn't supply (low-output single coils), so the signal to noise ratio was a little too low, and it introduced noise.
