Home Forums Products Stompboxes Help with TimeFactor freak out :( Reply To: Help with TimeFactor freak out :(
#122424
    Look and see if this is only affecting those parameters programmed to the expression pedal. If so, you may have a bit of dirt in the socket – try plugging and unplugging the pedal ten times. A little WD40 on the plug might be useful.
    If this doesn't do it, it would sound like a hardware problem – support@eventide.com
