Home › Forums › Products › Stompboxes › Help with TimeFactor freak out :( › Reply To: Help with TimeFactor freak out :(
August 10, 2011 at 4:32 am
#122525
The problem you describe sounds identical to the current affliction my TimeFactor is suffering from. I would be very interested to know whether you were able to rectify the problem and also the steps you had to go through in order to do so. Was it a hardware issue or did you find a fix you could administer yourself?
Thanks in advance!
