Reply To: Eventide Timefactor and Voodoo Lab Ground Control Pro
Home Forums Products Stompboxes Eventide Timefactor and Voodoo Lab Ground Control Pro Reply To: Eventide Timefactor and Voodoo Lab Ground Control Pro
#122607
badmelonfarmer
There are a few ways to do it depending on what you want to do and you can combine the methods too.
1. What Nick said, that is a great way to do it.
2. On the GCP you can set the Program Bank changes to send out Program Changes on different MIDI Channels.
I used a combination of these two methods to do it.
I had the TimeFactor on MIDI chanel 2 and then I programmed the Bank switches to send the relevent Program Change number I wanted for each device.
So button 1 might send out PC5 on MIDI Channel 1 and PC15on MIDI Channel 2 etc
so by using the map on the TimeFactor and the MIDI Program Change commands that the Ground Control sends out…. you can acheive quite a lot.
There is also a GCP programming utility for windows that can help with the programming of the GCP …. it is free and not supported…but once you get your head arround the GCP interface I don't really think it is needed, but it is great to get started.
Cheers
Martin
