Home Forums Products Stompboxes jumpy pitch with exp pedal – do i need a linear pot? Reply To: jumpy pitch with exp pedal – do i need a linear pot?
#122679
Hi David, thanks for your response.
Strange though, I did try a Roland EV-5 but it didn't seem to work very well (sorry, I already forget what the problem was — I tried quite a few different expression pedals, none of which worked very well), so I'm surprised to hear that it works fine for you — I wonder if I was doing something wrong?
The Moog MP-201 looks like a nifty gadget indeed!  I guess you must be controlling some Moog boxes as well?  Are you sending MIDI info to your Eventide boxes with it as well?
And yes, that is a great suggestion, to test out my theory with a 25k linear pot and see if it improves the pitch flexing.  If it works, then I could customize my own expression pedal.
Alec
