Home Forums Products Stompboxes Beta 3.5.0 strange programm change behavior Reply To: Beta 3.5.0 strange programm change behavior
#123133
thanks for the answer. Both Eventides are set identical but behave differend and both wrong.
I've checked my RCV MAP and it is on the default setting:
1>1:1, 2>1:2, 3>2:1....100>50:2
Both do a program change when I send it via midi on the correct preset/program number but the TimeFactor goes in bypass or stays in bypass on program change to the preset and the ModFactor goes active or stays active on program change to the preset.
Right way is, that the pedal stays in it its actual state and only do a program change to the preset. Nothing more.
I've tested a different midi controller on the eventides and tested the controller with other gear.
Sorry for my bad english, I hope you understand what I mean.
regards
