Home › Forums › Products › Stompboxes › ModFactor Midi Help? › Reply To: ModFactor Midi Help?
#123136
achaput
    You could try this-
    Save a preset with intensity all the way off in a :1 slot. Save your preset in a :2 slot. When you send a MIDI program change, select the first preset, which essentially has no effect. (Similar to DSP Bypass.) Then when you want to activate your effect press the Middle Footswitch to load the :2 preset.
