Home › Forums › Products › Stompboxes › Top 10 Annoyances of Factor Pedals › Reply To: Top 10 Annoyances of Factor Pedals
February 21, 2012 at 9:11 pm
#123150
Hi fjurden
To address #3 Midi Program Change: It is possible to have "asynchronous program change." You just have to set up the XMT and RCV MAPS accordingly, and you have to make sure your MIDI OUTPUT is on THRU (not XMT) for all the devices that are slaves in the chain. So, if you want the PF to be the master MIDI controller, you set up your XMT MAP how you like and set the OUTPUT to XMT. For all the other devices in the chain, set up the RCV MAPs however you like, based on the XMT MAP of the master, and set all their OUTPUTS to THRU.
