Home Forums Products Stompboxes Time Factor Dave Kilmister presets settings! Reply To: Time Factor Dave Kilmister presets settings!
#123292
badmelonfarmer
    http://www.eventide.com/AudioDivision/Support/Stompboxes/TimeFactor.aspx
    V3,5 contains the presets and there is a PDF explaining the presets.
    If you mean you would like to see the values for the knobs, the you can either use catchup mode on your time factor to find the values or use factor lib to display the knob positions.
