Home Forums Products Stompboxes Can a stompbox foot switch be assigned as a hot switch? Reply To: Can a stompbox foot switch be assigned as a hot switch?
#123384
achaput
    I didn't completely understand your question.Which stompbox are you using? Only SPACE has a Hotswitch.
    Do you mean you want to use the Eventide's onboard footswitches for Bypass and Hotswitch? On Space you can already do this in PLAY Mode.
    Or do you mean that you want to operate Bypass and Hotswitch over MIDI?
