Home › Forums › Products › Stompboxes › presets stored in the bypass › Reply To: presets stored in the bypass
May 14, 2012 at 4:00 pm
#123428
It's not possible to save a Preset in the Bypass State. However, there are a couple ways to accomplish what you are trying to do. One would be to store a preset at 0% Mix. (This would be the same as DSP Bypass.)
Another would be through MIDI. You could use a MIDI controller to send a MIDI Program Change command that will put the unit in Bypass.
