Home Forums Products Stompboxes Exp Pedal and Morley A/B/C Reply To: Exp Pedal and Morley A/B/C
#123469
jmusolino
    I got hold of a Morley a/b/y and ran my PF into the A side with the EB Jr in the input to see if it would get a signal. Unfortunately, it didn't, but I'll try some different cable combinations and see how that works. The idea here is to be able to choose at any time the Factor pedal or pedals that use the exp pedal. So if I'm using the PF to change a harmony from a 3rd to both a 3rd and 5th to a 5th and I'm using the MF and TF as well, I'd use the a/b/c to choose only the PF with the exp pedal. Or maybe the PF and TF. It seems that the midi cable connection with a single exp pedal would cause it to change parameters on all 3 pedals. Thanks…Joe
