Home › Forums › Products › Stompboxes › Time Factor ‘Line’ Noise › Reply To: Time Factor ‘Line’ Noise
June 15, 2012 at 3:44 pm
#123548
Thank you for the reply. The setup I used ha been the same for the past two years and that is the TF is connected via the RG16 from RJM Technology (audio / loop switcher rack) through the amp's Series FX loop. The pedal is set to 'Line' and while I'm not so sure whether the Killdry is on I've tried it with bith on and off and the problem remained the same.
