Home › Forums › Products › Stompboxes › Start up modification question › Reply To: Start up modification question
November 8, 2012 at 4:16 pm
#123981
You should never power up ANY audio equipment with amplification on – speaker damage is likely. If you love your speakers you will turn the amp down before powering off, and only turn it up when everything has powered up.
That said, you could experiment with the different bypass modes – some may be quieter than others in your particular configuration at power up.
