Home Forums Products Stompboxes Hold down the left footswitch and turn on pitch factor Reply To: Hold down the left footswitch and turn on pitch factor
#124112
    Interesting.  It seems that you've stumbled upon an internal hardware testing procedure of Eventide's.  Once in that test mode, the encoder selects the particular type of test, and the left footswitch appears to display the test in progress, or the results of a test after it's been halted.
    01 TEST ALL
    02 TEST ALL  NF
    03 TEST ALL NL
    04 MEM ALL
    13 SYSTEM RAM
    18 DELAY RAM
    22 FLASH RAM
    31 MIDI PORT TEST
    51 ANLG AUDIO
    81 FRONT PANEL
    82 DISPLAY
    91 AUDIO THRU
    These tests take a long time to complete.  At least some of them allow your dry audio through (with the occasional decaying high B sine beep blocking that for a moment).  There are a lot of P= E= T= notations; each followed by a numerical value.  PASS – ERROR – TESTED?
    I've seen this kind of thing in many synthesizer applications, but I can't recall finding stomp box diagnostics like this.  It's usually triggered by a combination of commands that are unlikely to be hit inadvertently.  Nice find (although I'm not so sure that Eventide would agree).  Perhaps there are read/writes in the processes (or something similar) that shouldn't be interrupted.
