Home › Forums › Products › Stompboxes › PitchFactor Preset Programming: “Other” Effects › Reply To: PitchFactor Preset Programming: “Other” Effects
January 2, 2013 at 4:26 pm
#124141
SquareTremolo
Mix = WET:100
Pitch Mix = A10+B10
Pitch A = ArpA: OFF
Pitch B = ArpB: OFF
Delay A = GrvA: A07
Delay B = GrvB: B07
(encoder) = PEGGIATOR / TMP ON
Depth / Key = ATK: 0
Speed / Scale = LN: 1/32
Xnob = FXA: OFF
Ynob = FXB: OFF
(EXP PED Heel) = LN: 1/16
(EXP PED Toe) = LN: 1/64
Sharp-edged tremolo effect that instantly varys between silent and full amplitude. Uses Delay A + Delay B groove pattern :07 to create the effect.
Expression Pedal:
Because of the groove pattern construction, the effect rate is slower than expected. Use the expression pedal for slower and faster rates that remain sync'ed to tempo.
