Home Forums Products Stompboxes PitchFactor Preset Programming: “Other” Effects Reply To: PitchFactor Preset Programming: “Other” Effects
#124142
    StereoSlicers
    Mix = WET:100
    Pitch Mix = A10+B10
    Pitch A = ArpA: OFF
    Pitch B = ArpB: OFF
    Delay A = GrvA: A12
    Delay B = GrvB: B10
    (encoder) = PEGGIATOR / TMP ON
    Depth / Key = ATK:  0
    Speed / Scale = LN: 1/16
    Xnob = FXA: OFF
    Ynob = FXB: OFF
    (EXP PED Heel) = ATK:  0  FXA: OFF  FXB: OFF
    (EXP PED Toe) = ATK: 10  FXA: FLT 1   FXB: FLT2
    Two groove patterns combine rhythms for a single slicing effect.  Find two patterns for Delay A and Delay B that compliment each other.  Sparse rhythms leave room for a 2nd pattern.  Most slicer effects become more distinct with Mix = 100% WET.
    Expression Pedal:
    The envelope attack over each step increases from full amplitude to 1/10th of the step duration.  Two different filter patterns are gradually blended in from the effects section.  Individual slices become more staccato and frequency-dependent at the toe position.
