Reply To: PitchFactor Preset Programming: “Other” Effects
Home Forums Products Stompboxes PitchFactor Preset Programming: “Other” Effects Reply To: PitchFactor Preset Programming: “Other” Effects
#124143
SpinSweeper
Mix = WET:100
Pitch Mix = A7+B10
Pitch A = ArpA: OFF
Pitch B = ArpB: OFF
Delay A = GrvA: A03
Delay B = GrvB: B04
(encoder) = PEGGIATR / TMP OFF
Depth / Key = ATK:  -5
Speed / Scale = LN: 250 ms.
Xnob = FXA: OFF
Ynob = FXB: OFF
(EXP PED Heel) = LN: 250 ms.
(EXP PED Toe) = LN:  50 ms.
Stereo panning effects.    In a mono application, it's closer to a looped attack delay effect. Two offset groove patterns alternate active step positions.  Pitch Mix attempts to correct for the maximum level difference in the Delay B pattern.  The slow attack setting for Depth / Key sweeps the patterns left to right (and back again).
Expression Pedal:
The heel position resets to the default cycle rate [250 milliseconds).  The toe position ramps up the speed to the 50 ms. top limit.  This can be useful in emulating a Rhodes or Leslie effect (in conjunction with the rest of your pedalboard).
