Home Forums Products Stompboxes Looping video using the Pitchfactor Reply To: Looping video using the Pitchfactor
#124327
    Nicely done.  It's similar to how I approach the PitchFactor, except I use multitrack recording in a DAW (software) application.  Your timing is very good.  The Digitech isn't locked to MIDI Clock, and that's something that's always held me back from a hardware looper approach.
    Do you use the same hardware setup live with other musicians, and have you found it to cause any timing issues in that situation?
