Home Forums Products Stompboxes Timefactor issue Reply To: Timefactor issue
#124334
    You may have a problem with the center footswitch (this is the one that would put it into update mode). Try "wiggling" it a bit to be sure it is not stuck in some way. If the problem occurs again you should talk to your dealer, or support@eventide.com as it may be a hardware fault.
