Home Forums Products Stompboxes Another TimeFactor & Modfactor hum in Egnater Rebel 30 effects loop post Reply To: Another TimeFactor & Modfactor hum in Egnater Rebel 30 effects loop post
#124465
    It sounds like you have a large and complex setup, with a high likelihood of hum-producing ground loops. Diagnosing this is beyond the remit of this Forum – you may want to consider  professional advice.
    That said, using a central power supply makes ground loops more likely. To see if this is the issue, try using the Eventide power supplies, which have no ground connection, and see if this makes a difference.
