Home › Forums › Products › Stompboxes › modfactor power input issue › Reply To: modfactor power input issue
September 20, 2013 at 5:00 pm
#124828
I'm afraid you guess correctly. If you are using the supplied power unit and the MF is still in warranty you should probably send it in (see your dealer or support@eventide.com).
Otherwise, probably cheaper and quicker to find a friend with a soldering iron.
