Home › Forums › Products › Stompboxes › midi clock + midi through › Reply To: midi clock + midi through
#124916
    rdnzl:
    On the surface it seems that I can only have one (the clock) or the other (midi through).
    As far as the H9 goes (and most other MIDI pedals), this is correct. MIDI Thru is just the buffered input signal.
    To do what you want, you will need a MIDI merge box from someone like MIDI Solutions.
