Home Forums Products Stompboxes Pitchfactor signal chain placement quesiton Reply To: Pitchfactor signal chain placement quesiton
#124936
fkalich
    I run it a bit early.   Currently I have compression and an overdrive pedal in front of it.  The position of compression could change and come after it, I'm undecided on that.  I definitely want at least one overdrive or distortion in front of it, and I probably will place a second in front of it as well (I have 5 of those in my chain).   At times I would want a clean signal coming into the Pitchfactor, at other times not.   Other non-distortion effects definitely come after the Pitchfactor, I am pretty convinced that is the way to go in that regard.
