Home Forums Products Stompboxes Controlling two H9`s with one of them? (like you can on the factor pedals) Reply To: Controlling two H9`s with one of them? (like you can on the factor pedals)
#125015
h9controller
    Hi leejohan,
    Yes you can connect and have one H9 send program changes to the other.  On the master H9 you would need to turn on MIDI Program Change Transmit.
    This is located under System Mode.  The path would be: System Mode->MIDI->PGM.XMT. Turn this to ON.
    The slave unit should, by default, be able to accept these Program changes via MIDI and you're all set.
