Home › Forums › Products › Stompboxes › Timefactor MIDI works up until 13th bank › Reply To: Timefactor MIDI works up until 13th bank
December 30, 2013 at 9:18 pm
#125179
You should check (if you have not already) the TX MIDI Map on the TF. If that is OK, the problem could be at the Line 6 end.
