Home Forums Products Stompboxes different aux switch/ex pedal per preset? Reply To: different aux switch/ex pedal per preset?
#125661
gkellum
    The expression pedal programming is per preset, but the aux switch programming is global.  The one exception to this is for Space algorithms where you can use the HotSwitch functionality to create different parameter value positions in a preset which can be toggled with an aux switch (or the performance switch on Space).
    You might want to try using the expression pedal mapping functionality instead of the aux switch if you want your control to be preset specific.
