Home Forums Products Stompboxes different aux switch/ex pedal per preset? Reply To: different aux switch/ex pedal per preset?
#125662
    Depends on what you are trying to do, but consider that if you setup your aux switch as if it were a pedal, the stompbox will not see a difference, and you can then use the switch to control parameters on a per-preset basis.
