Home › Forums › Products › Stompboxes › H9 midi cc for pitch › Reply To: H9 midi cc for pitch
April 5, 2014 at 7:57 pm
#125665
All of the pitch flex presets are designed to work well with an expression pedal. So, what you're going to want to do is assign a MIDI CC to control the expression pedal patch. There may be one assigned already by default. If I had a PitchFactor with me I'd check, but I don't. But if you go into the system settings of your PitchFactor, you should see that in the MIDI settings section.
